4AGE 16V - need help (About distributor)
scomatic
Kota Bharu, Kel
Hi there,
Is there any way for me to using the 4AGZE Distributor to 4AGE 16v non-tvis? need any modification?
I think only AW11 s/c use distributor(and maybe some AE92 first batch s/c),afterthat they use twin coil wasted spark,no distributor
1.AW11 distributor+AE92 4AG ECU =Cannot,different cam angle sensor
2.S/C Twin coil sensor + AE92 4AG ECU= Dont work also since AE92 4ag ECU only send single signal to coil
Just my thought
Just my thought
Ermm... if using the S/C ECU ni? the big problem is can suit into the 4AGE?
If u have N/a 4ag and wanna use S/c ecu can,but have to use the sensors from S/c engine,which if it fits your engine,i think on 16v should be no problem.Use back you n/a injectors,advance the timing a bit.Better if u use S/c wiring and rojak with your AE92 n/a wiring,all good to go
Cuscostrutbrace,
well explained and i totally agreed wif u in ur earlier explanation. Very correct bro!
Regards,
Mike
