Performance tyres for 15"
Any one here used michelin Pilot Sport 3...any comment?
Pilot sport 3 not bad also..tested a friends spectra using this tyres..he bought at rm220 perpiece..good grip in dry and wet..wet tested at genting road..not bad..
Will take into consideration when next tyre change
haishh...life is difficult after ad07 discontinued.
kilang papan now famous for what tyres? :)
federal RS-R or kumho exsta.....buget performance tyre. Federal rs-r is 310 at jooi seng klang....kumho ecsta duno wat price but heard below 300.....
with that kind of budget, I'd choose a combo of rear RE001/T1R/whatever tires in the range of RM250+, and Toyo R1Rs for fronts.
You can run a maximum of 205/50R15, but hard to find those tires. RE001 have those sizes, and they're only made in japan, can get, but no shops stock it AFAIK, and the only way is to order beforehand. RE001 in 195/55R15 and 195/50R15 are made in Thailand. Toyo, Recently ordered (4-5months ago, I think) and can get 205/50R15.
205/50R15 and 195/55R15 almost the same size in height, the only difference is the extra 10mm of width.. looks wide when installed on a civic 5th or 5th gen.
Sedan cars, don't use grippy tires at the back... you want a bit of give when doing sharp corners. If using both grippy tires, need to run harder suspension to get the benefit of faster cornering speed. If not, welcome to world of massive understeer.
And if you're that particular about grip, get an LSD. That makes a difference even on standard tires, esp. during wet weather.. nothing is more annoying than having one tyre slipping when going over puddles.
using t1r 195 55 15 before.....good grips wet & dry but too damn cepat habis...currently using federal 595evo price rm200 all inclusive in rawang.....not recommended in wet...(thinking of selling it as >80% still there....anyone?heheh)
For 205/50/15 tyre, what is their normally price? Planning to change the front tyre (T1R now) with that size. Now running on 195/55/15. Another question, what about the BFGoodrich? Is it okay in terms of performance??
