what kind of fuel regulator r u using?
how is ur fuel regulator setup?
do u remove ur original fuel regulator ?
its good to hear ur problem is solved sir, mine too. mine was solved right after i changed to a new battery, my battery started to spew fluid and overheated, there was a shortage in the wiring and damaged the battery direly. now it starts on the first crank.
ur bobbing problem is the fuel running rich sir, because u r using a much larger fuel pump. u can lower down the fuel pressure to overcome dis bob-noise, and save fuel for a fair amount.
The lack of handling and grip is there when taking corners...
