ORI WALBRO 255lph fuel pump
yung
this walbro fuel pumps have latter to prove is original,MADE IN USA
WARRANTY:3mont
this walbro fuel pumps 500hp also stable air fuel ratio
walbro high pressure electric fuel pumps are available in flow ratings of 255 liters of fuel per hour.these particular pumps flow significantly more fuel at higher pressure .for example ,at 80psi the standard 255 lph pump will flow around 132 L per hour .at the same 80psi the equivalent high pressure fuel pump will flow 210 L
CALL 014-6411291 to order
bro, can fit with N.A car ? any problem for N.A car ? Will this fuel pump make N.A car fuel tooo much n burn the plug ??
How much plus installation ?
Thanks
---------- Post added at 12:41 AM ---------- 6 hour anti-bump limit - Previous post was at 12:41 AM ----------
Thanks
Thanks
Thanks
yes this fuel pump is suitable for n/a car,this fuel pump will not use too much fuel then stock but will add the h.p,because this fuel pump is very stable air/fuel ratio so it wont use too much fuel but will add h.p
bro, my car already tuned the ECU, is it nid to re-tune after install this fuel pump ? total how much plus installation ?
Thanks
Thanks
no need to retune your ecu,if u want also can because this fuel pump can support enouf fuel for your cylinder ady and air fuel ratio also stable,we dint provide installation,u can call 014-6411291 for best price
bumpssssssssssssss
---------- Post added at 08:18 PM ---------- 6 hour anti-bump limit - Previous post was at 04:02 PM ----------
bumping
bumping
---------- Post added at 10:23 PM ---------- 6 hour anti-bump limit - Previous post was at 07:01 PM ----------
bumping
---------- Post added at 11:52 PM ---------- 6 hour anti-bump limit - Previous post was at 10:23 PM ----------
bumping
