hi all,
the standard tyre size for our stock rims is 215/45/17 right? how about if i put in 225/45/17. if there any much different in handling, looks, etc?
please advice..:hmmmm:
Go do a google and search for a "tyre bible"....then you can get optimum fitting for your rims.
Irrespective of what tyre you use dont forget your suspension,alignment toe and camber.
dear taiko, correct me if i am wrong,
should be 17 x 7j, offset +50.
7j shud be able to handle width of 215 and 225.
too wide and speedo accuracy will be affected, though marginally
http://www.tiresizecalculator.info/
Hi there, need some advice from all sifu, our Altezza can clear rim size 17' front 8 1/2' off 30, rear 9 1/2' off 40 ?
