83mm piston on 20v
normality78
JB
Some 83mm piston taikor, when you guys use Nissan / Mazda 83mm piston, do you guys mod on the piston to clear the additional valve seat? coz 20V is running 5 valve whereas those piston was taken frm 16v
care to share?
haha.. 1st concern is 20V block can bored 83mm or not ? if can reliable or not ?
am i right ? pls comment..
whahahah. cikopek u.... u bukan 83mm taiko... so shu shu...!! go away... whahahhaha
I think it can bore to 83mm because normally saw on magazine almost all is wrote 83mm piston. But I personally saw few people who did it, found all is facing reliable issue.
For you to run 83mm safely without much issues, re-sleeving is a must. Sure you can rebore the block without any re-sleeving but then it will be VERY thin.
EFN bro,
hm.... since the block is cheap, i may wanna try w/out sleeve and see how far it can hold
before u bore ur engine, u have to make sure ur engine block is VERY healthy...
better use on 7A block for better respond..
since spend money on bore the engine, why not try on 7A?
The last i found, synchron bro use 83.5mm. amazing... wonder what piston was that
bro normality, change another car that already done modification la..... hehe
hehehe, i know what you're saying. In fact i did toying this idea. but then how am i going to sell mine to get yours? Wahahaha... unless you're a car dealer
you can put on Internet. Hehe. As ae101wong said if your mech do not know how to modify it will got many problems. I can't say that my mech very well in modify this but at least he done few 7A with or without oversized piston without any complain including mine.
ngjenwei.. your car use 7A ka... cant wait to see..:burnout:
