water temp gauge rise when headlights on
arrowhead
Damansara/PJ
ok as topic mentioned,
i have their weird issue. my water temp gauge, will rise when my headlamps are turned on. it'll go above normal... and when i turn off my lights, it drops back to normal temp. when i on my headlamps and drive around again, it rises again.
what the hell is wrong? i've changed both my temp sensors (there's 2, 1 for the ecu to read, the other for the gauge to read - located further in, between the radiator hose)
what else could cause it? i have grounding cables? 1 is connected to the thermostat radiator hose...
help. its annoying. =(
relay? hmmmm...
how about grounding cables... would a better one (branded) be significantly better at grounding as compared to a cheapo one?
Check your thermostat ... it might be faulty .... Fix mine by changing a new thermostat ...
bro, its not that my car water temp increase, its just the meter... it shows higher than normal, but only when i on my headlamps... once i off, it goes down straight away back to 1/3 of the gauge.
so its not that my engine is overheating or anything, its just the stupid needle on the meter getting false reading..
Arrowhead....issit when u turn on yr headlamp...suddenly the needle jump up...then when u turn off...the needle suddenly go back to normal?
very wierd...better send to wireman to check....sounds like got wrong wiring oni...dun wait got short circuit n electrical fire....
ya thats what i thought.
alright, latest update
i added additional grounding cables... so far so good
*fingers crossed*
but seriously la...original grounding wires should be enough to stop these sort of grounding issues....i still think better send to pro wiremen to check...wiring i really dun dare play a fool with...
1 example...1 BMW E28 guy decided to DIY the wiring for his brakes i think..dunno how he do but ended up when he started the engine...n press brake...the muffler exploded! i'm not joking. i saw the muffler peel along the seems. my foreman say maybe cos engine had wrong signal n overloaded the A/F and caused too much air to go thru system n muffler cant take it exploded....next time i go back i take picture n share...that car is now a donor car for my family's E28 repair project hehehe.
my foreman oso dun dare to start that donor car...he pushes the car everytime he wanna move the car around his workshop...
moral of the story...dun play around with wiring woooor
thats a freak accident! yeah, original grounding should be sufficient, however i strongly believe mine is due to me -repainting my car. probably painted over the metal surface of the body/grounding point hence this problem.
