Haltech Platinum Series
Good News For RX7 and RX8 Club.
The Platinum Sprint RE
Engine Suitability:
• 2 Rotor Engines - 2nd Generation RX7 (FC3S)/Turbo II, 3rd Generation RX7 (FD3S) and RX8 (SE3P)
• Normally Aspirated or forced induction
• Load sensing by throttle position or manifold pressure (MAP)
• Sequential Injection
• Distributor ignition systems or multi-coil systems
Trigger Types:
• Reluctor
Trigger Patterns:
• Mazda Rotary Multitooth 24 and 2
• Mazda Rotary RX8
Pls Contact Your Haltech Dealer for more Information
Good News
For all waja engine and campro cps or non cps can running perfect with Sprint 500.
Pls contact your Haltech Certified Tuner.
Platinum sprint 500 on Toyota Lexus 6cylinder VVT
http://forums.haltech.com/viewtopic.php?f=3&t=5652
---------- Post added at 11:01 AM ---------- 6 hour anti-bump limit - Previous post was at 10:49 AM ----------
VR6 running Haltech E8 semi-sequential.(6cylinder)No dramas.Can use for Perdana V6 turbo.
VR6 engine Je Pistons, Eagle rods, T3 60-1 Turbo Haltech E8 semisequential injection wasted spark ignition on stock coil pack
373WHP@ 1Bar boost
YouTube- Corrado VR6T 0-260 km/h
Hey Syahz, PMed you regarding kelisa and haltech Sprint 500. ANyone here knows if Kelisa 2nd generation can tune ignition timing with Haltech 500? Coz i heard cannot tune with Emanage since using cam sensor.
ALso, will the Haltech 500 work with 3 cylinder supercharged Kelisa? Thanks for any help.
Cheers,
Ed
The 1st and one only the Suzuki Swift Sport Performance runing Haltech Platinum 1000.
Good idle,aircondition and street driving with out any dramas.Thanks to SportCompact Racing.
YouTube - Swift Sport Performance.mp4
Cheers,
Ed
No worries for kelisa 3cylinders.we know the trigger type and set up.May be u can ask the haltech Tech for the clear message.Or u can ask your nearest dealer.
Haltech Platinum Series 350Z - By GT Auto : The only Dealer for Haltech in Malaysia
http://www.gt-auto.net/images/stories/cars/08/z/pic/IMG_3642.JPG
http://www.gt-auto.net/images/stories/cars/08/z/pic/IMG_3637.JPG
http://www.gt-auto.net/images/stories/cars/08/z/pic/IMG_3652.JPG
full link:
http://www.gt-auto.net/index.php?option=com_content&task=view&id=32&Itemid=55
Haltech Platinum Series - Interceptor
BMW 540i V8
http://www.gt-auto.net/images/stories/cars/08/e34v8/pic/IMG_3521.jpg
http://www.gt-auto.net/images/stories/cars/08/e34v8/pic/IMG_3527.jpg
http://www.gt-auto.net/images/stories/cars/08/e34v8/pic/IMG_3522.jpg
http://www.gt-auto.net/images/stories/cars/08/e34v8/pic/IMG_3514.jpg
Full link here:
http://www.gt-auto.net/index.php?option=com_content&task=view&id=31&Itemid=55
350Z already use Pro Platinum plug in.And more function for tuning.
You can refer with super duper dealer Haltech or Haltech Certified Tuner.
Good News
Hello Syahz,
Since campro cps or non cps are "drive by wire", electronic throttle body, how can there wire (ETB)connect to Sprint 500 ?
Is Sprint 500 support "drive by wire" ? please correct me if i am wrong.
Bye.
Platinum 1000 push up the Swift at 147.4whp petronas 95 fuel at dyno dynamic.Wait for 2nd tuning with Q16 race fuel.
Hello Syahz,
Bye.
Suzuki Swift Sport same running electronic throttle body.The car still good respond with VVT.So what the problem Platinum to running this system.Ask your super dealer Haltech at sunway for more detail.
Hello Syahz,
I goto the web site : www.haltech.com and look all the product.
I look on their specification, it seem they forget to mention on "drive by wire", electronic throttle body,ETB.
So, sorry to ask which Platinum model that support ETB ?
Thanks.
Hello Syahz & ecupro,
to my understand Haltech unable to tune drive by wire but also not sure is it apply to all the range correct me if im wrong. some ppl say they use OE ECU to control the Drive by wire and the rest of the tuning was done on the standalone.
Hi xbalance2002,
Long time no see,how are you?
After you mention on OE ECU that control ETB, then, I fully understand.
So, thats mean, the OE coolant sensor must be connect on the OE ECU in order the ETB can work on "COLD STAR".
So, thats mean, the OE air-cond switch or sensor input must be connect on the OE ECU in order the ETB can over come the stready r.pm. when air-cond cut in or cut out.
Thanks again, xbalance.
bye.
Syah, can the Platinum 1000 series ECU work for the Satria Neo CPS? Any CPS installed before and what's the outcome? thanks.
Haltech Platinum can be tune.Ask your super dealer or Certified Tuner From Haltech.He can help u.
syahz...
are you the same Syahz Microtech @ rpm2racing?
how's Haltech S500 on Toyota 4AGE 20V and cost? can it be wired up to use either wasted spark or edis?
coz I'm trying to eliminate the use to distributor...:proud:
tq...
