Hi bros... need some help with my newly installed Works fuel regulator.
Here's the issue :
Everything went perfectly after it was installed until i re-started my car few hours later. This weird whistling noise came out from the regulator. i've tried pulling out the vacuum pipe that connected to it and the whistling sound came out even louder from the regulator. so, i thought it was the faulty regulator's prob. yesterday, went back to the shop and exchange for a new one. after installation, everything is perfect again.
Then this morning when i started my car, the whistling sound came up again. is this a vacuum problem? i'm using the vacuum pipe from the standard fuel regulator (which is using the power of 1 piston vacuum). should i find a 4 piston vacuum line? Anyone facing this issue with Works regulator?
Need all of ur imput as this sound is very annoying. FYI, the pressure adjusted still stays there @ 3 bar. nothing wrong with the pressure.
pls help... thanks
Here's the issue :
pls help... thanks
bro, my blue EVO 3 has got stolen at Christmas eve in Klang, any one see any EVO 3 pls PM or call me because now day there are not much EVo 3 left in the road. Sayang man, i have fully suit up the car and i...
