Engine Oil for high performance engine
syaq0707
To all u playaz..juz wanna asked u guys opinion regarding the engine oil..the the b16a engine already change to hi cams, pistons,.......then what is da suitable engine oil..is it use the honda engine oil by idemitsu the fully syntetic one, or motul turbolite or anything laa..juz give advise la from all da sifus!! cheerss!! PPPrranngg!!!
Re: Engine Oi for high performance engine
syaq0707,
My personal opinion MOTUL is the answer to you Q.
If you have budget MOTUL 300V are the best.
u should try lucas 5w30 + oil stabilizier.....
long lastin.....
oil pressure n oil temp more stable......
u try it...
u will stick to it......
---------- Post added at 02:14 PM ---------- 6 hour anti-bump limit - Previous post was at 02:11 PM ----------
engine oil with "ester oil" is gd...
not not lastin..
max 4000km,the lub wil degrade.....
better flush ur engine since u r changin to a high quality oil......
try blue chem oil system cleaner.....
very safe to use....
has anyone tried M7 engine oil?
i vote for motul or torco... if on budget get Mobil 1 fully syn also ok.. depends on how deep is ur pocket and ur preference of brand....
but motul seem to hv good and + views from most users
motul is good choice......semi sync (4100 or 6100) is as good as many fully sync in the market.
eneos is the engine oil supplier for both toyota and honda worldwide now
they have a new range of 0w20 oil dat meets the latest specification for oil quality, shud give u sum idea on what to choose for. expensive oil like motul doesnt mean its the best
eneos engine oil not bad...:smokin:
Used Eneos 5W/30 for quite some time ....... Performance wise quite stable n when drain out oil not like kopi O' n smell bad .
Go for Motul....i currently use honda idemitsu fuly sync..not bad ah ...but will kurang abit the oil if u keep rev and touge ....
vtech b18c or k2oa better dont save...
sometimes depend on how old and how long u have maintained it. depends on situation my point of view
long lastin.....
u try it...
not not lastin..
bro what oil stabilizer bro... sound interesting
last time, long2 ago (LOL), i remember, most dragsters were using chemlube. dis is a time where there were no motuls, eneos, lubri-moly, castrol edge, etc. its made outta high quality ester and wud last very long, most importantly, its relatively cheap. esters dont wear out fyi, the additives jer yang abis and needs to be replenished.
i know of racer dat is still using dis oil, and change oil in his race car once a year jer..
---------- Post added at 09:49 AM ---------- 6 hour anti-bump limit - Previous post was at 09:40 AM ----------
oil nowadays doesnt need any stabiliser, at least not in ur daily application
VTECs do consume a lil of oil, normal ler.. especially when driven "normally", lol
fast, "saving" for me means spending on sumthing cheap but has no quality. spending excessively on sumthing dat has low quality is just pure stopidity. if u can spend less for d same quality item compared to a more expensive item, y not kan? high quality products dont have to be so epxensive, if u know how to search for it, imo ler
i have no idea what with it..
but jus add on 2 ur engine oil..
u will fell the different....
pm me if u wan...
gd gd rate for member
---------- Post added at 12:29 AM ---------- 6 hour anti-bump limit - Previous post was at 12:26 AM ----------
pm me if u wan...
I would said 5w40 or 10w40 Semi or fully... but as for brand i try few already with the same price, i think I will never use MOBIL again... for some personal exprience(which I was so supprise how come Mobil become like that when i install into my DC2(B18C)...nvm... try stick with 5w40 or 10w40 semi or fully.. i guess that is my choice..for me No More MOBIL
mobil gold with grade 5/50 or 0/50 got too many additives...not gud for high speed or modded car..
will stat to get lesser by time if u use in performance car....
get 10/40 or 5/40..semi/fully will do...dont buy the normal fully syntetic..get performance oil-even semi is better than fully syntetic...
if ur car is very high hp etc 600 and above u should use 15/50
