down boost on e-manage
bikerz
i have increase my 4g93t to 1 bar boost and tune it with e-manage. Now, if i down boost it to 0.6 bar, but dont tune my e-manage back, what will happen? engine running super-rich? or e-manage will adjust accordingly by itself?
actually what i want to achieve is better fuel economy, so is it better for me to down boost?
Nothing will happen to your engine...
Just the following:
Engine feels sluggish = due to too rich. Engine response feel heavy.
Carbon accumulation on the piston crown = due to unburnt fuel remained in the engine.
Possibility of back fire
Fuel consumption wise, bad and not effective.
No, e-manage will not adjust by itself. But ur OEM ECU will try. But only up to a certain extend. Even the, it's also during close loop(Idle n cruise)
Advise, retune.
i tot stock boost is 0.7-0.8bar, can go down below the stock boost?..
u tune with 1 bar..?
so it will optimize ur fuel n air at 1bar rite....
last time i boost at 1.3bar with emanage tune...my fuel as if oem factory
i thought with the 3bar map sensor emanage will change to appropriate afr as what the current boost..
sorry, i mean stock boost, so 0.7/0.8. so, if e-manage tune at 1 bar, better fuel consumption at 1 bar than low boost right?
no la, use in uni, short distance only, thought of lowering the boost for better FC...
can... can adjust on the thread of the actuator rod connected to the internal wastagate. loosen it. release the exhaust abit to reduce the boost.
depends on how you step. And OEM is normally tuned to a little richer AFR to be on the safe side.
I would say more fuel efficient at 1bar.
Smart choice.
haha..just shift gear whenever ur boost meter shows "0" lo, then ma save fuel ade..
now my car FC is 13.3L/100km, is that normal for 4g93t?
dat's slightly higher than my prev gsr with afc neo also tuned at 1bar..my prev was ard 21cents/km with normal driving(not boost all the time, just when overtake cars)..urs is 27cents/km..
maybe due to my gsr engine with putra g/box?
A little too high.
If not mistaken, putra GB quite long... 10+km/h @ 3000rpm @ 5th gear.
maybe because bikerz is driving around Uni.... And short short distance where most of the time is running on h within the campus. And it's not fuel efficient.
only one way,no power but engine safe
i bought this car 2nd hand, come wit putra gearbox. use gsr better? less screaming when cruising?
u want use for road or drag or hi way race?
---------- Post added at 01:25 PM ---------- 6 hour anti-bump limit - Previous post was at 01:19 PM ----------
the gear box bearing lor
