I'm using evo 6 stock engine , and i've 1 e-manage on hand .
currently planning to set ecu , either to reflash / re-map stock ecu better , or install the e-manage to tune better?
can sifu here giv some opinion?
I just wondering, is it all ECU can be reflashed?![]()
i would go for reflash as u can map the whole ecu and not just a few points
summroe u can lift the boost cuts and rev cuts off the ecu
i tink u have to explore www.evolutionm.net , lots of info
Interesting Q, I also would like to know
Hi guys,
What ecu are you using bro evo_kaki?
I have an evo 2 stock ecu...don't know whether to re-chip it or to get an emanage.
I know a chip will remove all the cuts...but will it be able to be tuned to the mods on the car through the chip?
Like how an emanage will be able to be tuned...
Any feedback will be appreciated.
Thanks all.
reflash ecu + emanage is still alot cheaper than standalone. as long it do the job and give you desired engine respond n power is good enough.
just got my ecu reflash .
Setting include remove speed cut, rpm cut, boost cut and also tunning for air fuel & ignition timing .
Satisfied with de horse power came out from stock engine , but not satisfied with the price to reflash which is high.
:sleep:
