Federal RSR
currently using 595evo after been using some time i wan to change some wheel setting.
I notice the tire outer wear off higher then my inside tire...
current setting is camber 1.5 maybe later will try camber 1.8~2.0 to reduce the outer wear uneven ...
will i reduce the braking performance in strait line due to the higher camber setting?
guys im going to change tire which to buy Federal RS-R or Kumho KU36? as both are very good tire... help
BTW how does this RSR looks like? Never seen one b4...
Federal RS-R
http://imgcdn.adoosimg.com/6993d6e3b0ec30fd904e7beb849e854f-1-3.jpg
Kumho KU36
http://www.good-win-racing.com/mazda-talk/images/SEMA07b.jpg
currently i using toyo T1R now 235/45/18 si pak noisy when doing 80 its like driving a small lori :biggrin: but its good in wet. i test hit 200kph in rain XD i survive !
r those tyre showing above noisy too?
any1 know how much its cost?
thanks
thanks
T1R dont grip so well.... so so only
Noise level is high...but grip level is even higher then T1R
for this 2 type of tyre price for 15" 3++ per rubber....for 18" dont know
thanks
usually from what i know,the more the rubber come to contact with the road,the more noise it produce.
just my 2cent.
aih...always try to find the tire when i can afford it, no stock...when got no money, everyone call and say container arrived edi....alas, i settle for 2nd hand AD07 by chance
SURE.....I called the shop in front of Jin... the boss told me 195/55/15 R888 sell rm350/piece... so the wind blow to Ah Jin ears...
wah my mouth really drop off now .... this R888 is version wat? compound version 2 or version 3 or got other version
