engine oil i use M7 GT engine oil 5w40, oil filter M7 magnetic oil filter, magnetic oil sump nut. rear differential oil i use Q8 Synthetic oil, ATF i use Q8 ATF also.
most of the shops can do if u bring ur own stuffs,...otherwise u gotta go to reputable shop like in pandan indah, sunway, subang...they got wat u wan.
unless you want to do it yourself, better get the oils that you want to use then most workshops can do the change for you la. Reputable shops sometimes the oils are a little expensive, but you can scout around.
i know bolting on a t/kit on a EFI engine would be a better choice..but wats the process on a carby?
estimated costs?
components? my wira is a lil slow..haha!:confused_smile:
