Newbie in Turbo, need advise
kanan
What is the best solution when turbo have a little oil leaks. I'm using 6A12TT engine. just checked this morning the front turbine got little bit of oil leak. The sysmptom is you get little bit of smoke coming out when warming up but no more when engine really hot. Checked head no trace of oil leak.So should i service them both? cost around rm500 per piece, or to have a piece of mind should I changed to a new one set of turbine with similar spec? or is there any after market turbine that fit right to the original mounting? if not what's the possible reliable solution?
same like my kancil last time, but i ignore since no major problem. maybe ur gasket loose or something u press kaw kaw?
If td025 ... to me its not worth it to service because u can find so many selling at halfcut and turbo shop ... try to find one in good condition ... gamble abit la ... kekeke ... sumtimes it might last u for years sumtime it might last you for a couple of weeks ...
but then if ur looking for peace of mind and have some cash to spare ... service it :)
if i were u .. i would fin me two TD04-09 and then kacuk with the TD025 exhaust housing ... u will be amazed with the performance gains :)
TD04-09 are very durable turbo's :D
perhaps u can change evo 3 :biggrin:
seje je rakesh.too late bro:biggrin:
---------- Post added at 07:11 AM ---------- 6 hour anti-bump limit - Previous post was at 07:05 AM ----------
td04-09 from which car bro im not familiar?or issit after market?can it fit into the back space without ketuk firewall?
---------- Post added at 07:15 AM ---------- 6 hour anti-bump limit - Previous post was at 07:11 AM ----------
Call Turbo Pro Melvin aka SDF.He can advice u la bro..hehehe
he has high end turbo only hehe not for my car la
aiseh bro...Lan_eterna doing that at his workshop.. or buzz Danz for further information
2 downpipes for rm350
Will go to get the J approval first. then can mod without excuse :biggrin:
Hahaaha...already install 6a12tt into your car.Upload some photo here showing the leakage part.
It will be helpful.:smokin:
