4G93T plus mivec head
smallmaster
Johor
SIFU.
Wat is the difference after put mivec head into gsr engine !!! got any torque difference. plsss elaborate... pilisssssssss:confused::confused::confused::confused:
u got a high revving engine...higher rev means higher horsepower...with the torque advantage over the 1.6 mivec because higher cc...u can do some search in the forum...it's already been discussed...
i dun think higher rev = higher hp... in general that is not true..
however, with the mivec head the camshafts profile is not the same as the standard gsr.. therefore you will have peak torque at a higher rpm range compared to stock gsr head.
just make sure your mechanic knows what he is doing if you want a good mivec+gsr hybrid.
timing belt is not the same. now u need an electronic device to activate mivec... fuelling & ignition map should be tuned as well. not so easy as it seems.... if you want the mivec exhaust sound.. i have to disappoint you.. in a turbo engine you can hardly hear the mivec engage.
all in all... i think the GSR tomei 270deg camshaft will do a better job if you are looking for top power.
mix n matching Mivec Na Engine with turbo block+ Piston isnt a walk in the park...
yeah even mitsubishi evolution until generation 9 only come out with mivec turbo bro..
so is not easy to accomplish this task
Wahahah! this is great! i got one frd playing mivec turbo last few years ago.
he got 327whp. freaking fast. he was using td05 and more .. ? i don know .. haha.. but it is so fast.
Agree with bro contreasjun27. only until evo 9 develop mivec turbo.
last time my friend bold on a 4G92 + GSR turbo kits in it..
with unichip setup can reach 3xx whp with just td04..
i guess a whole mivec engine bot is better than 4g93t pluck in a mivec head haha
---------- Post added at 09:50 AM ---------- 6 hour anti-bump limit - Previous post was at 09:43 AM ----------
True dude. 4g92 BOT is much better. Ya the result is much powerful.
yeargH is true 4g92 BOT is much better &powerfull if u know how to increase the whp using single cam not twincam....
mivec head put on gsr i think no point..still same the power..i agree BOT on mivec engine is better and can beat gsr....hehe..
I already do R&D to 4g92&mivec BOT result is excellent and powerfull...can drag with 2.0 engine....
to smallmaster better u just upgrade ur gsr engine....see de result..
strongly agree with that...
4g92 mivec engine BOT is crazy fast!!!
as the mivec response better than GSR ploking a Mivec head haha
