Mitsubishi Turbo specifications.
hi guy,looking for etena twin turbo spec 6a12tt...can change bigger turbo ? what model of the original?itzit td025?
Hi sifus... I'm planning to BOT my 4G92P SOHC. I'm planning to BOT a low pressure turbo. Which would be around 0.4 bars... I'm in the process of buying items for my project...
But I came across this problem of identifying which turbo to use... May I know what's the difference between TD04H and TD04L...
Is there any problem if I use TD04H??? Can anyone help me...?
nope u can use TD04H or L or HL no worries..diffrent between L or h or HL is their internal part that all..but still in same family of TD04..:driver:
thanks... But I've already got myself a TD04L... I guess not so much of a problem kua...
does actuator attached with da turbo?wats da part number?u can c on da compressor housing..
Yes... suppose to come together... But, if you chose to use wastegate, u can ignore the actuator.
Part number from the drawing is 12501
add a wastegate, then say bye bye to the current actuator.
i'll sealed for good and brought to the grave ;)
guys...got 1 noob question..
TD05 and TD04 using the same adapter ker?
do i need to mod the adapter?
Bump: guys...got 1 noob question..
hello guy i want ask about turbine evo3 big 16g how many HP can sapport ?
and and if modified gsr engine fully modified do i have to change the turbine mine use TD04L
thank you
thank you
td05h big 16g can make 350hp,ofcourse cant use td04L to make fully modify car coz turbine wheel will going out from the exhaust lol~
guys..
i got this turbo,didnt seem to find it codes from the first page
it is TD04
49177-01700
need help here..
what engine does this turbo belong?
is it good?
this turbo this TD04-11B single blade,is very good for low rpm like 2.5k will full boost already,it very response turbo,but untill 5k rpm will drop power band,many diesel car is use this turbo
thanks bro.
is this turbo using ball bearing?
i dunno how to differ between non BB n BB turbo..
so,the power will drop at 5K-ish laa?
if we r using cam that power band until 7k,does this will cover that?
yes will help hi rpm flow if you got hi cam,but that got limit,not so good for hi rev,mmc turbo always is use journal bearing is not ball bearing,good luck
TD04 GOOD FOR 2k until 5k rpm... It spool fast !! But after 5k rpm to redline... OUT OF BREATH AD !!
:thefinger:
even if using hi-cam also dosent have power ka?
i got this cam power up to 7500k RPM...how if i use it?
