- Check diagnosis error code...
- check AFM pin connector...make sure it's secure tightly...
- check park plug, cable plug and distributor all in good condition...
- then...reset your ECU...see if the trick works...
Hi folks, need help my SW20 develop weird problem after the Genting session. On the way back from Genting fuel cut at 3000rpm countless times. Only able to drive slowly and unable to accelerate as fuel cuts when...
