bro,
may i know the setting of the adj. cam pulley? afraid that is setting for pick-up, not for top speed. nice mod u have there.
or myb u can try to clean the carburator.
or, change open pod filter
yup, might be the adj cam pulley is set for pick up which surely will sacrifice your to speed...another thing is your rear mufler, is it straight flow or 's' flow coz this also afect pick up and top speed..however, looking at your dyno sheet, u might need to tune (lean a bit) your fuel regulator to gain better top speed as well....(don't forget to use lighter 15" rim) huhu
I understand that the VG30DETT and the VQ30DET are using ballbearing turbos as the stock turbo...
If it is thru is there anybody here that can source me this turbo...
need urgently...
