Do you notice something on this?
TRD.AE92
Hi there,
Please check the attachment. Do you found something wrong on this oil filter?
That means it is used for 4AF, 4A and such excluding 4AGE. I think it has something to do with the flow of oil.
the ''4A-G series'' means 4AGE also excluded..
except 4age?? how come???
Yes... you are right...
I go to buy Toyota Original Part oil filter... There is Toyota oil filter is not design for 4AGE, 4AGZE, and 3SGTE....
---------- Post added at 08:52 AM ---------- Previous post was at 08:51 AM ----------
Yes.. correct too...But It very important?
---------- Post added at 08:52 AM ---------- Previous post was at 08:52 AM ----------
the ''4A-G series'' means 4AGE also included..
Yes... Included as well
There is another version, slightly bigger than this picture. Written 4AGE compatible and for 3SGE too. I take picture on my next service. I notice this filter too, and discontinue using it. Compare to the filter that i'm using (original Toyota), it has a difference 0.2 bar oil pressure once you do the swap.
last time also got difference.
C1 vs C2 if im not mistaken.
so, nowadays oil filter E1 vs E2. made in thailand
E1 smaller, and E2 is bigger
E1 murah sikit and E2 mahal sikit
technical specs? carik itu chinoze punya website. should be there.
Yeah... there are the E2, but support for our 4AG series and 3SGT series...
ermm... you have picture to differential for them? Because most of ZTHrian will not aware of it.
just a question:
- does it effect the vvt? with difference of 0.2 bar pressure
i've already change it with that oil filter too..1st look at the box make me curious too..ask the seller but they tell also can for 4age..rite now nothing different before n after change it:biggrin:
Dude, already stated not compatible for 4AG (including 4AGE, 4AGZE and 4AGE 20V). You can still fit it though, but suspect oil press will drop (more noticeable during VVT activation) and insufficient oil filtration.
Physically, the E1 is smaller and E2 is bigger. Price wise not much difference, maybe cost RM2-3 more only.
Just my 2 cents...
Like that tiu lo.... any problem using E1 arrr??? Just check with my mech.. he been changing E1 oil filter for me all the while....:banghead:
This is correct oil filter for 20V:
90915-YZZC6
90915-YZZE2
C6 is using sponge like filter element while E2 is using paper. Could be due to different filter element, E2 is slight taller than C6.
If using a wrong oil filter, perhaps the VVT pulley will die earlier (produce "clack clack" diesel sound)??
Different pressure needed to push the oil. I see. Flow design is also what comes to mind. Unless someone can buy one and cut it open sideways, then we can see the difference. But since the packaging already stated so, i think it is wise to follow it.
die lo... all this while i'm using E1 and pressing the oil hard....
any after effects (other than the taxi sound)?
Wahahaha... I already know many people will not aware of it... Lolzzz
How bout info from this website?
http://www.filmantravel.com/20vparts_files/
---------- Post added at 12:41 PM ---------- Previous post was at 12:41 PM ----------
20 VALVE (20v) 4AGE PART NUMBERS
For Sale, Working 20v manual STARTER, tested at parts store, $53 shipped.
Part Name Part Number Cross Reference
Timing Belt 13568-19035 Gates T081, Goodyear 40081, Beck Arnley 0260254
Timing Belt 13568-19185
Distributor Cap 19101-16010
Distributor 19100-16270
Distributor O ring All 4A
Igniter 89621-12050 SW20
Ignition Coil 90919-02197 3SFE, 2JZGE
Ignition Rotor 19102-74040 Beck Arnley 1737967, Kem W2052, Wells JA995
Spark Plugs 90919-01178 or 01179 PK20R11 or BKR6EP11, Nipondenso 3128, NGK 2978
Spark Plug Wires 90919-15207, 90919-15206, 90919-15205, 90919-15204 Magnecor
Coil Wire 90919-13418
Spark Plug 5 Wire Set 90919-21520
Spark Plug Valve Cover 11212-16060
Air Filter 17801-15070 4AFE or 7AFE
Oil Filter 90915-10002 1989 Supra fits
Oil Filler Cap 12180-46010 Supra 2JZ, Stant 10113
Outer CV Boots 04438-12260 Repco 200-037
Inner CV Boots 04438-12420 Repco 100-051
Head Gasket 11115-16111 TRD, Toda
Engine Gasket Kit Valve Grind 04112-16210
Engine Gasket Kit Valve Grind 04112-16330
Camshaft Intake Seal 90311-40016
VVT camshaft valve 15330-16010
Intake Valve Guide Bush 11122-16030 std, 11122-16040 sub, 11123-16030 o/s 0.05
Exhaust Valve Guide Bush 11126-16010, 11127-16010 o/s 0.05
Intake Valve Seat 11132-16030 o/s 0.03, 11147-16030 std
Exhaust Valve Seat 11135-16030 std, 11136-16030 o/s 0.03
Valve Stem Oil Sear or O Ring Exhaust 90913-02092 Echo, Prius
Valve Stem Oil Sear or O Ring Intake 90913-02093 Echo, Prius
Valve Adjusting Shim (Lifter Valve) 13751-16020
Valve Cover Gasket 11213-16020, 11213-16021 sub
Cylinder Head Cover Nut, Washer 90176-08047, 90210-09016
Rear Main Seal Felpro BS40409, Beck Arnley 052-3258, Corteco 17199
PCV Valve 12204-11050 Standard V330, Napa 2-9405
PCV Valve Grommet 90480-18001 HELP 491036
Catalytic Converter Gasket FELPRO 23591
Spark Plug Tube Gasket 11193-16010
Brake Booster 44610-1A420
Brake Booster 44610-1A430
Idle Speed Control Valve 22270-16030
Fuel Pressure Regulator 23280-16140
automatic Starter 28100-16170 4AFE auto starter fits
automatic Starter 28100-16140
Alternator Belt 99365-80840
Alternator 27060-16330 4AFE alternator fits
Alternator 27060-16360
Air Flow Meter 22250-16110
MAP Sensor 89420-12070
Intake Cam Sprocket 13050-16010
Exhaust Cam Sprocket 13050-16040
VVT Cam Valve 15330-16020 blacktop
Engine Bay Wire Harness 82111-1E220 (91-94), IE771 (93-94)
Thermostat 90916-03090 All 4A
Accessory Belt AC & PS 99365-21060
Water Pump 16100-19245
Water Pump O Ring all 4A
Water Pump Gasket 16124-16040
AC Compressor same as 7AFE?
Power Steering Pump 04454-12010
PS Belt Adjusting Bracket 16381-16070
Idler Pulley 13505-16021
Idler Pulley 13505-16030
Spring Tensioner for Idler 90507-19003
Bolt Flange for Idler 90105-10334 4AFE, 7AFE, blacktop
Pin for Idler Spring Tensioner 90249-06006 4AFE, 7AFE, blacktop
Coolant Temperature Sensor 89422-35010 WELLS SU4007, BECK ARNLEY 158-0421
Oil Pressure Switch (with gauge) 83520-35030 NIEHOFF OPT24821, BECK ARNLEY 2011130
Blacktop ECU 89661-1A360 95+
black = blacktop only silver = silvertop only blue = both
Maintenance parts are being stocked by JayMarks Toyota in Houston (now called Champion Toyota) at normal prices. The in-house 4AG expert's name is Jeff and the number to reach him at is 1-800-327-2087. If you've ordered parts from there, email me and let me know how your experience went.
20V Swap Info
20V Sensor Locations Vacuum Hose Id 1, Vacuum Hose Id 2 Engine Manual Club 4AG
Each of the two brake booster vacuum lines needs it's own check valve before the T fitting.
SILVERTOP MAP CONVERSION
I will explain how I got a good vacuum reading for a MAP sensor on a silvertop 4AGE, but for the rest of the conversion you're on your own. With quad throttle bodies, if you draw vacuum from a single throttle, the vacuum will pulse rapidly making it unusable for a MAP sensor and less than ideal for anything else that uses vacuum like a fuel pressure regulator. You have to draw from all four throttles to get stable vacuum. The solution is a lot simpler than what I was lead to believe. The 20V 4AGE has a "vacuum rail", basically a chamber that is already tapping off of all four throttles for you. It is on top of the throttles between the fuel injectors and connected to the PCV, often beneath part of the engine wiring housed in a plastic cover. It is being used by the AC, power steering, and there is another small line drawing from it I'm not sure for what. The problem with using this vacuum source is that it is being used by the IAC. To overcome this you basically need an air chamber that is larger than one inch inside diameter. I'm not sure how long it needs to be, but I'm assuming it should be at least one inch also. Get a carbuereted fuel filter. One of the clear ones, with fittings about the same size as the AC vacuum line,.. well, that's where I hooked it up anyway. If yours isn't free, get a t-fitting and splice it in there. Leave the element in the filter, it wont hurt anything and it will add an extra layer of protection to your MAP sensor. I got a T fitting and some reducers and connected it to my MAP sensor and fuel pressure regulator. Now the fuel pressure is a stable 37 psi at idle, and I am able to map out my fuel curve with the AEM EMS. I'm willing to bet it will work just fine with a blacktop ECU if that is your plan for the conversion.
COMPRESSION CHECK
When shopping for a 20V 4AGE, check the dry compression. There should be less than 14psi difference between each cylinder, 156 psi minimum pressure, ideally 193 or more.
Thanks Matt from Toyospares, Shane, Skydrol, Orlando, JR from AEM, gramma, Linda, and Eazy E.
IMPORTANT NOTE: I did not come up with this page, or the part numbers. I only copied this from shaundrake's (guy who used to be on club4ag.com) site. So I really can't vouch for the accuracy of the part numbers.
n
guys, seriously need advise on 4AGE 16V pistons in 4AFE 16V block. my car is in the workshop getting an overhaul now. handed them the pistons for the swap...some mechanics say can but some others are skeptical! Made me feel kinda scared and indecisive now. Any advise is much appreciated. thank you
