Myvi Make Sound During Cornering
Mr_KrOnIkz
Terengganu
Dear All Knowledge Guys,
I just bought Myvi at August 2009,after get the car I make some alignment at workshop.A day after that I go the the workshop again coz the alignment is not working good.Then they change the front rims,which left part rims goes to the right part.A week after that is good but then i hear some sound come out from rims when i make a cornering or U-turn on the right side.The worse sound can hear during U-Turn.During driving I also hear tik-tik sound at the right rims along the car is moving.I already check it at Perodua SC but the problems still happen.Is that my drive shaft is broken?Guys,I need ur opinion bout this.So,help me ok.Thanks.
normally that is a sign of your driveshaft ...when you take a sharp corner,full steer..there is a tak-tak-tak sound....
but your car only 2 months old????? i dont think it can be spoilt so fast right?
Yeah,my car still young.But it happen after i do alignment cos they fix the camber and change the rims position.But the sound make my ride not good.Feel angry with that sound.Like an old lady.
send back to the alignment shop ??? ask them to check
under warranty ......u may go check out at perodua service centre....
bro...pls make sure that when u make u-turn...see either ur tires got 'touched' with ur car chasis or not..
plus u r using stock rims?
for ur information when u r using a bigger rims in ur myvi...it wil scraps wit ur body chasis which is d wall which separate ur engine wit ur wheel arches...pls check it..
bro my car also same,my wan worst..after send to service center for the disc skimming than the next 2 days i went to put air in the tyre than i saw greese on the left hand side.i straight took back to service center than they told me the drive shaft got problem, so they changed a new one for me..
did u lower ur car?
if yup then normal la for the driveshaft to broken...
if you guys noticed got loud sound whn u drivin at uneven road then pls check the absorber link...
sometimes it loosen & it reali spoil fast
my car is standard bro..onli 6 months..yea i notice that got sound when drive at uneven roads..so juz tighten the screws at the absober link there can d ??very leceh wan la when hear those sounds..
u can try tighten it
but if it reali broken then u need to change it
local/taiwan is around rm55-65
original from perodua is rm150
if i wasnt wrong but tis is per piece not per set
My car still standard and use all the basics.I not modified anything yet...mybe at the future...
try check the clearance of the tires
see wil it touch the inner wall o not
---------- Post added at 01:24 PM ---------- Previous post was at 01:23 PM ----------
thanks bro..i will try tighten it..
no prob bro...
js helping out onli....:driver:
Just want to know which link you are refer to...got any pic? i am doing troubleshoot on mine at the moment but so far haven't found the root cause
darkwizard...i think i saw ur nick in http://www.myvi.com.my forum
so u already kno who i am...
abt pic...i need search ya..pls hold on
---------- Post added at 01:37 PM ---------- Previous post was at 01:34 PM ----------
bro darkwizard....pls click on the link
http://myvi.com.my/forum/index.php?topic=597.1680
at the 3rd pic is the absorber link
---------- Post added at 01:37 PM ---------- Previous post was at 01:37 PM ----------
Yesterday I already go to SC and they say nothing broken...the drive shaft is ok...
but after i go home the sound come again Sh**....But it make a sound when i corner slowly like an auntie...after this I should take fast cornering...
which SC u went to?
