how to built 2.2 stroker kit???
ronniehor
any one no how to built 2.2 stroker kit;
piston size???
conrod size???
crank size???
etc:
thanks
hihi...maybe some day lal....i am beginner so need some advice,i here some story got some con shop using OEM piston and cut the piston head and do the con job ezzit true???,and the con shop change to the owner mahle forge piston price ezzit true???
tats just lower the compression rite....size the piston size remain, cc remain..rite?
I dont think is to lower the compression, but is coz the piston is tooo high & it will hit the engine head or damage the top part.... Also the top part of the piston is the most presure part in the engine w/ all the heat. I dont think I wanna cut the piston head leh.... hehe
ronnie,
Not con shop lah.... I will said is cost saving mah.
ronnie,
most car cut the piston head, especially those cant find replacement piston. i.e for BOT purpose or boost higher application
Ronnie,
You mean got customer found out about this?? Hopefully the truth will be revealed and justice can be done. :mad:
Wiseco sells a stroker piston, 131.50 rod length with a -17.8 Dome Dish.
Pair that with the 2.5 Liter STI Crankshaft. The only thing is the shorter connecting rods. I think PE sell one.
The rod in ej25 and ej20 is exactly the same
