[WTA]B16B Valve Springs
SimonsayZ
Puchong
Hi all sifu, Wana ask if B16B valve springs can be used on B16A?
Will it make any difference or must it have to match with B16B cams? :hmmmm:
Definitely can.....
Like pencalat said....better to match with b16b for more performance....
but even if you use on b16a also can.....
Can be use but I think cannot feel any power up lor.r Because u still using b16a cam.
Ok thanks all sifu for the info. :adore:
So that means no point even if I use it with stock B16a cams. How much are the B16B cams selling in the market now?
Yea...if you're getting it for damn cheap or wat..then buy 1st and keep..no need install..save on labour...until you get the cams...b16b Rm1xxx...
type R valve spring is double.one big one small spring to make sure ur valve din float on high rev. valve float at high rpm can cause piston to valve impact and ur compression wont be that good on high rev coz the valve is float and din seal properly for the compression stroke.
very2 correct la..
EK4 also have dual spring for both side..
Better u keep the money get the b16b high cam only install together. Don't waste the times and money on the valve spring. Because valve spring very hard to install.
agreed with u guang.....
korek..korek..
