Swap knuckles of different PCD
ExceL
Ampang/KL
Currently my car comes with PCD100 knuckles. Because so many old skool rims are PCD 114 (4hole), I would like to change my knuckles to that PCD. Afraid to drill because it does not sound or look safe at all (to me at least).
My car is ee90, what knuckles can I use?
edit; oh wait, I have to swap the disc as well
drill the disc la... Many people also done this and didn't seen any problem pun.
What other alternatives are there? I would consider drilling as a last resort at this moment.
Conversion spacers are out of the question.
spacer much easier.. 100-114.3.. but u say out ouf question.. ask the mekanik.. i saw a lot KE70 using nissan knuckle
spacer is much easy to convert the PCD, but very very hard to get it le... if got also price very high.
anything please think about safety...SAFETY
exactly why I'm trying not to consider using spacers or drilling.
I may not be an engineer, but somehow drilling more holes into a piece of metal that rotates at high speeds just dont sound safe.
yes, drilling, spacer/converters or special nuts/bolts wont provide good balance while spinning at high speeds. it'll wobble. you'll need very high precision CnC machines (for drill and spacer/converters) and this is costly.
and once kena bump on malaysia roads.... starts to wobble.... my friend experience, thought sharing it here.
Hi,there is enough space for d disc to drill hole.but at d screw locate,i think no space for d screw.anx idea?
Thanks
hi to all....my fren did use the pcd converter to his ee90 and using back wheel rim 15" size...
to weird bro for the front..the rim too too too "terkeluar" from fender and u cant turn ur steering either left or right max coz its hit ur fender...
any idea on this?????
Offset problem
hehehe...no use la if change pcd to 114.3 esp SE and not using lips rim...but wat to do...ask for bodywork..they suggest to make widebody....my fren still thinking..
