changing to larger rim
michaelkomodo
hi bro n sis, i've change my rim from 13" (tyre 175/70/13) to 15" (tyre 195/55/15).. anyone know how to calculate the speed?
wat i mean is, 110km/h on 13" may not b the same as 110km/h on 15".
thanks
thanks
http://www.carbibles.com/tire_bible_pg2.html
remember to scroll to the A tire size calculator to calculate
what i did to compare 13" (tyre 175/70/13) to 15" (tyre 195/55/15), the result says that when your speedometer read 110kmh, actual speed might read slightly faster at 113.88 kmh
too bad, i'd changed to 195/55/15 before asking this question... but thanks a lot on ur replies...
wat tires u change..?? just sell it off then get the 50 1 loo... if Neova, i dun mind buy from u... hehehe...
finally, i shoot on the right spot... thanks bro...:adore::adore::adore:
me got from calculations... you got frm experience :adore:
no biggie.... just remember to maintain slightly below the speed limit lor
or you can sell it to jin hehe
bro's...i think it wouldnt be so accurate on the calculations...
if ur using 195/55/15 against the new bigger rim of 215/40/17 you will experience slight decrease in pick up but better top speed due to rotational mass of the larger rims..
according to the calculator, 15' is traveling 70mph and 17' will be 73.34(roughly)...wouldnt u guys think that the 15's are easier to spin than a larger wheel?
the calculater i've featured is to see how much variance in the speedo when you upsized/downsized the driven rims thats all.. no relationship to the performance in any way....
i've heard that in some country if you upsized ur rim and its produce more than 5% variance in the speedo reading is illegal...
hehe... witout huge power output, even i give it 18" still can't reach 230kph in a stock Myvi loo...:rofl::rofl::rofl:
ur car speed reading is the same in any rim size ,only ur rpm wil be different when u change gears,pickup wil reduce and many more.try maitaning this size tire in ur 15 inch rim-185/50/15.it wil b lighter.........
Why? Mind to elaborate more?:confused:
