any sifu can help me identify the problem pls? i recently convert my kancil to L2S manual with 125000km on odo. full tank of fuel only get me about 260km !!! i dun have a boost meter yet so i dunno boost how much, assume its stock boost. no modification done on the engine, just a k&N open pod air filter.
things i've done while converting the engine
1. changed engine oil motul 10w40
2. changed oil filter
3. changed timing belt
4. changed valve seal
5. changed water pump
6. changed fan belts
7. changed clutch assembly
8. changed MTF
9. changed brake fluid DOT 4
10. changed brake assembly
11.changed spark plug NGK ori.
bodykit is totally stock, mine is round eyes kancil. no hood scope. intercooler top mounted as stock. everything is stock. no aftermarket blow off valve.
why the fuel consumption is high? there is no jerking on engine, idle is stable, temperature is normal for the engine. i've raised the bonnet abit so that hot air can vent out. thats all. anyone can help me? izzit the ECU problem? can i reflash the ECU? do i need the ECU codes to do reflashing? pls help.. cause the fuel consumption is even worst than my ori 850cc carburator engine (340km per full tank)
p/s: i drive normally with occasional small boost.. my rpm never over 5k
8. changed MTF
