- Joined
- Jan 20, 2007
- Messages
- 439
- Points
- 1,518
hahahahah bai itu barang boost con ke picagari?
satu kali henjut 1.9 bar pecah gua rasa itu barang:proud:
satu kali henjut 1.9 bar pecah gua rasa itu barang:proud:hahahahah bai itu barang boost con ke picagari?satu kali henjut 1.9 bar pecah gua rasa itu barang:proud:
for me the best is TURBOSMART e-boost(using it for about 5 years,no problem at all)![]()
you need jo1This is for monster only whose need boost beyond 40psi...
i dn't want to be monster like you la bro jo1....just like the 'TURBOSMART' wording only...ha3..This is for monster only whose need boost beyond 40psi...
not good enuff la..hi all,
how about the works-engineering manual boost controller? anyone try it before?:hmmmm:
not good enuff la..
if u wanna buy that then beter buy turbosmart boost tee...cheap and very very good...
http://www.turbosmart.com.au
wow... turbosmart !!! very impressive ne.
Bro, I just add on turbo kit for my small cc 4G13p oni... but u all is with monster car leh.
TD04L , injector still stock..... wlabro fuel pump installed edi. When boost around 0.2~0.3 bar the check engine indicator "blink blink" wow...
Might need go for bigger cc injector & FPR...? But some giving idea such as add a boost controller to set the boost for 0.25 bar to solve the problem...
guy's... any suggestion not?
Thanks ....![]()
sure la check light come out...
the original 4g13p runs on map sensor...when the map detects boost the check light will come on..thats totally normal...
if u have a piggy bag ecu or something all u do it clam the voltage of the map sensor and the right voltage b4 boost then u have solved this problem d...
no no no probs...piece of cake!![]()
bro, my blue EVO 3 has got stolen at Christmas eve in Klang, any one see any EVO 3 pls PM or call me because now day there are not much EVo 3 left in the road. Sayang man, i have fully suit up the car and i...
