- Joined
- Apr 25, 2008
- Messages
- 79
- Points
- 1,506
[WTS] [MaxAudio] Sound Proof - Free Shipping / Free Installation
Purchase Any Product from MaxAudio.Com.My/ MaxAudio.Lelong.Com.My and get FREE INSTALLATION at Max Automart
Send an E-Mail to [email protected] & get 10%-30% Discount Coupon for MaxAudio.Com.My (Valid Till 31/8/09)
CARFIT Custom Made Bonet Sound Proof Myvi, Wira, Iswara, Waja, Kenari, Kelisa, Viva, Old Saga 89, Saga BLM
http://www.maxaudio.com.my/images/uploads/Carfit-Bonet.jpg
Promotion Price: RM48
Comfortable Drive
Protects paint work
Shields from engine heat
Dampens vibration thus reducing road & engine noise and body panel vibration
Insulates sound contributing to better music reproduction
Insulates against rain drop noise on motor roof
Reduces creaking & rattling noise
Self-extinguishing
Waterproof
High-temperature resistance (-40C to 105C)
Durable
Environment friendly
Model Available:
ISWARA/SAGA '03/ LMST
KELISA
KENARI
MYVI
VIVA
SAGA '89
SAGA BLM
WAJA
WIRA/ SATRIA/ GTI/ PUTRA/ ARENA
CARFIT Rear Trunk/ Boot Deadening Sound Proof: PROTON WIRA SEDAN
http://www.maxaudio.com.my/images/uploads/Wira-RP_Carfit_1.jpg
Self-extinguishing
Waterproof
High temperature resistance (-40ºC to 105ºC)
Durable
Environmental friendly
Product Weight: 0.5Kg
CARFIT 110Cmx90Cm Universal Bonet/Boot Sound Proof 2nd Layer [JC-068]
http://www.maxaudio.com.my/images/uploads/jc068-carfit-1.jpg
Size: 110Cm x 90Cm
Universal Fitting for All Cars
Can be use for Bonet, Roof & Boot
This is known as Heat Absorbing & Sound Damping Sound Proof, it can quite down engine and outside noise
This sound proof is known as 2nd Layer Sound Proof (Recommended to Install Layer 1 Sound Proof Known As Model: YC315 Silver Non Melt Rubber Sound Proof Function as Sound Proofing, Engine
Cooling and Sound Deadening for Maximum Sound Proofing Effect
Dust off the auto engine cover, and clean the greasy stain.
Cut the heat proof cushion at the size of the engine cover before you paste
Tear off the release paper and paste the heat proof cushion on the engine cover.
Smooth the cushion with gentle press, paying special attention to the uneven parts in the quarters of the squares and triangles
Product Weight: 2Kg
DEADENING JAPAN T4012 4 Sheet Sound Proof Made In Japan Best Recommended for 1st Layer Door
http://www.maxaudio.com.my/images/uploads/T4012_1b.jpg
Promotion Price: RM224
Best Recommendation for 1st Layer Door
Noise and vibration solution
Should be used on any and all interior sheet metal of your vehicle
Highest efficiency sound deadening material available
More effective at stopping noise and vibration
Aluminum constraining layer is very moldable and conforms easily
to all interior surfaces
Extra sticky patented butyl layer is formulated with VERTOR for the most amazing energy conversion capabilities ever.
Product N.W. : 3Kg
DEADENING JAPAN T4012B 4 Sheet Sound Proof Made In Japan Best Recommendation for 2nd Layer Door/ Floor
http://www.maxaudio.com.my/images/uploads/t4012b-sound-pad.jpg
Promotion Price: RM180
Model: T-4012B
Recommendation: Floor & Door [2nd Layer]
Thickness: 6mm
Size: 570mm x 480mm
Aluminium constraining layer is very moldable and conforms easily to all interior sufaces
Makes a difference in heat transfer
Hear will now have to travel through each of these materials
All of whcich heatdifferent levels of thermal conductivity
Works to confuse the flow of energy and is more effective than thicker insulations
Product N.W. :4Kg
DEADENING JAPAN T4012C 4 Sheet Sound Proof Made In Japan Best Recommended for Under Car Mudgurd
http://www.maxaudio.com.my/images/uploads/sound-pad-t4012c-1.jpg
Model: T4012C
Best Recommended for Under Car Mdguard
Thickness: 2mm
Size: 600mm x 480mm
Product N.W. : 5Kg
DEADENING T-4005 3 Sheet Sound Proof Made In Japan Best Recommended for Bonet, Ceiling & Boot
http://www.maxaudio.com.my/images/uploads/T-4005.jpg
Promotion Price: RM120
Made In Japan
Should be used on any all interiors sheet metal of your vehicle
Aluminum constraining layer is very moldable and conforms easily to all interior surfaces
Product N.W: 1Kg
Comfortable Drive
Protects paint work
Self-extinguishing
Waterproof
Durable
Model Available:
KELISA
KENARI
MYVI
VIVA
SAGA '89
SAGA BLM
WAJA
Self-extinguishing
Waterproof
Durable
Size: 110Cm x 90Cm
Product Weight: 2Kg
Product N.W. : 3Kg
Model: T-4012B
Thickness: 6mm
Size: 570mm x 480mm
Product N.W. :4Kg
Model: T4012C
Thickness: 2mm
Size: 600mm x 480mm
Product N.W. : 5Kg
Made In Japan
Product N.W: 1Kg
u can sell this item to me.(will consider the...
