DIY engine damper
erictan30
have anyone try to DIY engine damper?
i've seen some one DIY using Hood damper so it's cheaper
engine damper is tougher and shorter compare to hood damper lo...
but if u mount a few hood damper, it is possible geh...
but u must do custom bracket to hold it in place lor....
i have a friend mount 1 of the camry's hood damper the damper is damn hard le.aerospeed wan is much softer.and 2 hood damper will only cost 1/3 of the real engine damper..engine damper is also available for certain models only.also need to mod
so in conclusion, it is possible... jz that u need to find out which part of ur engine vibrates most when revving and mount the damper there... make sure the bracket is done properly and the dampers is stiff enough (but not too stiff la)...
i just done my engine damper with only $$ 0 spent.....i get the absorber damper from those absorber use in furniture one from my dad,n 2 pieces of steel piece.....den mount it on the engine mounting on the timing belt side.....superb result....
any pictures to share??
what the function of dis damper?to assist ori engine mounting?..
anyone can explain it?:hmmmm:
Actually it's use to hold the engine so it won't vibrate too much...The engine vibration force will absorb seperately by the mountings and the damper..
Correct me if i'm wrong...:biggrin:
