Amt power cushion buffer for coil spring
AMT POWER CUSHION BUFFER (for coil spring)
ADVANTAGE OF USING POWER CUSHION BUFFER
1. Rubber buffer can effectively solve the problem of springs weakness and recover the performance of the shock absorber.
2. Shock absorption effects felt in a mercedes benz car.
3. Protect shock absorber and suspension system to avoid oil leak.
4. The life of a normal shock absorber will be extended to more than 2 times.
5. Improve driving comfort and more stable during curve corner.
6. Improve braking efficiency.
7. Reduce noise and vibration during travelling.
8. Size for all type of car including lowered spring and adjustable.
10. Less sound and less maintenance for adjustable
Price for whole car RM90 for all size.
COD within klang valley(out of klang valley try call) and malacca
Installation location : My place near kelana jaya or your place.
Installation : Cheap and negotiable.
Installation including safety cable clip.
H/P :0162023768. Call or sms me anytime.
SizeA-gaping 47mm, thickness 13mm, diameter 173mm
SizeB-gaping 35mm, thickness 13mm, diameter 160mm
SizeC-gaping 27mm, thickness 10mm, diameter 131mm
SizeD-gaping 23mm, thickness 10mm, diameter 113mm
SizeE-gaping 15mm, thickness 10mm, diameter 112mm
SizeF-gaping 12mm, thickness 15mm, diameter 120mm
The above measuremnt for reference.
including myself...haha
