i wanna to use K1 Tech product
crankshaft 2.3L in my e3 engine...
question is, K1 Tech the best product or not???
need advice he3x
best and good are two diffrent things
i doubt K1 is the best
bt i know K1 is a good company
Carrillo owns K1
one more thing is that, if u aint going for drags and building 1000hp machines , a stock 2.3/2.4 crank from 4g64 is more than enuff
i wanna use on the road n illegal drag hehehe
wat about wira diesel 2L crank???
n now i already have 86mm wiseco, eagle rod, arp head n main
can i use k1 crank n how about cost???? :hmmmm:
yeap u definitely need a stroker piston to use the 100mm crank in 63 block. B.T.W OEM 4g64 crank is capable of handling up too 1000hp.No need to buy crank.If use wira diesel crank also need to custom your piston,this will take up to 4 weeks depens on the piston maker.I did mine with wiseco and takes 3 weeks to complete my custom stroker piston.
ohh, u custom ordered your pistons :P
tq 4 ur knowledge :proud:
Bump:
:hmmmm: how about cost 4 custom piston??
where can i get it???
n custom pistom=forged piston??
depens on how you custom it bro, normally around 500 - 650 (not including shipping cost n tax)
500 kupang ah ?
we have all the custom spec for your evo or 4g64 in stock..
from stock 150mm to 162mm long rod to 156 rods and stroker pistons and normal pistons..
wesico and cp in stock..
price from rm2000
price from rm2000
if u use stock evo block better use 86mm la..:hmmmm: wat about sr wiseco piston???can i use it as stroker piston???wat size suitable???86 or 87????
