- Joined
- Oct 31, 2006
- Messages
- 1,393
- Points
- 1,648
Erm, i need to ask a few question regarding triniti clutch on a satria gsr..as well as abit on gearbox..
first of all, here are some of the details that might be needed to make my statement more clearer..Previously i was using valeo clutch and satria 1.5gb and i've change to 4wd evo gb lock 2wd, 9' flywheel and triniti 6 puck racing clutch...the gearbox, driveshaft, flywheel is all halfcut condition while the clutch is new...
and after the installation and testing, i've found out that there is 2 new sound coming out from my engine..
1.First scenario..when i on my aircon, and idling, there wil be a 'tak tak tak' sound consequently follow by my cam settings, and when i idling rev it at 1.5k, the sound disappear, or when i press my clutch, the sound disappear too...when w/o aircon, the sound sometimes wil appear and sometimes wil not.
2.Second scenario..Let's say i'm on maintaining 3rd gear...and i slowly slowly increase my rpm to 5k without changing gear, then when i release the throtle paddle without pressing clutch, the exhaust wil be very loud(normal) and the new sound appear which is 'cccrrrrrrrrraaaaaaaakkkkkkkkkkkkkkk" til around 3k rpm then go off..tis happen in every gear, thus if the rpm is higher, the sound wil be louder...
Is this normal or abnormal?
3.Is 1.5gb driveshaft fitted well on an evo gb? I tried to use 1.8 gsr driveshaft but it was not fitted well, which when compared to 1.5gb and gsr gb, gsr driveshaft is a bit more longer..weird case..
I had dismantled my gb once again yesterday to check if there is any problem, added washer on the gearbox to make the clutch can step more further, changed new gearbox fluid...and the problem stil haven't solve at all...
5.When i engaged from 2nd to 3rd gear, there wil be a sound like if u didn't fully press the clutch, and u engage gear, the 'cruk' sound....is this gearbox problem ?
hurts ...
and pls do not think that this only happens to TRINITI solid hub, even extremely well known brands like ACT, Xtreme, Clutchmasters, Alcon...bla bla...has the same problem with their solid hub clutches that is why we say that each product has got their own pros and cons.
. in the 2nd movie they crashed not 1 but two monsters. 1 fd3s and 1 jza80
. what do you guys think? worth or waste?
