Oversize Throttle Body ! Is it the faster way to put out your engine potential ???
wow, very hard to understand what both of u written above.....I'm almost gaga @.@ n catch no ball.......
dear customDIY;
What you actually should do is simple, the list below :)
- Larger TB (RM250+-)
- PNP your engine head (RM800+-)
- PNP intake manifold (RM150+-)
- Skim 2mm off enginehead (RM 150+-)
- 3" CAI intake (Buy 3" PU hose from huakenny RM80+-)
- 3" OpePod (RM150+-)
- Aftermarket ram air manifold (RM100+-)
- Lightened flywheel (RM150+-)
- After market clutch (RM600+-)
- High capasity fuel pump (RM180+- from chop shop, walbro 225 RM650+-)
- Performance spark cables or upgrade ignition coil (RM300+-)
Estimated improvement should be 15-20hp increase, 40% performance increase, and 30% torque curve increase
Then you will see decent enhancement, by changing larger TB alone doesnt give much effects.
Coz either you DO, or DONT do......hehe
PS: After all calculation, BOT might be a better choice
yaka......
ha ha ha ha
how la bro, his formula get more than powerzone hehehehhe
depends what ecu u using and how big is ur oversize throttle body... if svdo, minor oversize still can be supported by oem ecu... mmc is abit stupid on the other hand, datz why need piggyback ecu....all sifus,kindly advice
after using a Larger TB..can the ecu adapt and adjust the AirFuelRatio ? Can a fuel pressure regulator be sufficient to support this mod?
or is it NECESSARY to get a vafc?
I guess the best would be to get a larger intake manifold along with a larger Tb then add on a vafc and send for tuning?
thanks in advance.
ur friends automotive engineers open tuning workshop tell u all this secret recipe??...:hmmmm:no wor, what is powerzone ? some cheapskate tuning for executive workers in office to believe lor.
this isnt my formula either, is experience shared among my friends who modded car, jinkl dun lcly lor, i know u plays turbo car, but are u an engineer buka tuning workshop ?
kakakakakakaka
kakakakakakaka
mmmm...
play with bigger tb u
need high lift cam,high rev,piggyback or s.alone..
