wira 1.6 single cam NEED HELP
huakenny
LB Performance
Kota Kinabalu
Hi,
recently dunno wat wrong wit the car
the engine can start and idle...
but if i accelerate, it will creates loud 'pop Pop' sound and car cannot drive now...
wat is the problem?
i hv change spark plug, throttle body, fuel pump....
wat else?
URGENT
Wira 1.6 EFI Single Cam
sounds like either misfiring or too much fuel...
if too much fuel.. it might be leaking vacuum hose or the fuel regulator jammed.
Sounds like you have a faulty air sensor so the car is running too rich~ or too lean~ whichever it is that is the first thing you should check before digging into more expansive probabilities.
airflow i changed edi tat day
fuel regulator not yet..will try this
