4g92p only 140km/h??
SATRIA5163
hehe.. my satria just can get 140km/h..:banghead:
so tension.. anyone know whats wrong with my car..?:adore:
izit bcoz of clutch plate? my clutch bearing always "ringing" unless i step a bit on the clutch pedal..but, still have a good pickup.. need to overhaul?
tq in adv..
have u try press full pedal
n call u friends to see the butterfly
Full Open or Not..
try n rectify ur "ringing" problem 1st. might b ur clutch worn/pecah oredi. checking ur tb also will help if d clutch is ok. im using 4g92p Auto stock std n d top speed will go around 170kph.
the sound like KRINGGG.. like something lose alredi..
i think its from rubber bush on the clutch link..whether from cluch pedal @ the bushes.. dont know whats it call.. want try to spry WD40 first la.. :idea:
b4 this, pomen told me that my TB alredi kong coz the idle wont get stable. but, after i make sure all the hose are tighly connected, the prob gone.. haiyoo.. pomen alway want to sembelih meh?? :stupid::thefinger:
not the tb i guess .. most prolly is ur clutch. Last time my 4g92p manual stock also can reach 190km/h ma lol ..
Bump: not the tb i guess .. most prolly is ur clutch. Last time my 4g92p manual stock also can reach 190km/h ma lol ..
ur technician helped u to speedcut isit ? my fren owned a sentra 1.6 also got once he also reach 140km/h max, den bring back to the workshop only said he speedcut it... my stock 4g92 can reach 190km/h when i was on the way to putrajaya to test my ride...i brought 4 friends together with me its 5 person in my car....
Bump: ur technician helped u to speedcut isit ? my fren owned a sentra 1.6 also got once he also reach 140km/h max, den bring back to the workshop only said he speedcut it... my stock 4g92 can reach 190km/h when i was on the way to putrajaya to test my ride...i brought 4 friends together with me its 5 person in my car....
is it you bought brand new or second hand..my car i bought second hand (4g1x) same problem like you, no top speed..when i overhauled the engine (leaking piston ring) i found out my camshaft badly worn oredi..that could be the problem..but if it is, sure pengsan lor..wanna check oso costly, have to go to eon service, they got special tools to change valve seat so can check..but if not, maybe try adjusting the tappet..but if still not, maybe need to tune your ignition timing..my car oso once have kringkring sound which maybe coming from the cover clutch..after tuning distributor sound much less or most of the time even gone..if still not maybe tb and injector need to b check or clean..
its 2nd hand one.. but get it from my mother in law.. for 10 years she use it, the milage is only 92K.. seldom use it.. hehe.. that y im dare to take her car..
hmm.. seem have to find good workshop to check it.. if not, for sure kena sembelih.. :banghead:
gud luck on your visit to workshop..to check cam, just go to any wsyop and tell them wanna adjust tappet..oso can see the cam that way..happy motoring
