- Joined
- Feb 6, 2009
- Messages
- 47
- Points
- 1,508
Hello everyone,
I would like to ask something about o2 sensor. Currently my car was doing bolt-on turbo and everything is fine except Engine Check Light on. Once the CE light on, TRC and VSC system disable which I don't want it happened. I did system diagnosis and it detected as "Fuel too rich" from o2 sensor. FYI, the ecu no longer can control injectors since I'm using standalone ECU.
So, is there any way i can trick ECU from getting signal 'Fuel Too Rich' from o2 sensor? I already did sensor relocation and still no luck. Currently I still find the right voltage to do voltage mod. But seems it will fail :(
.. so you have idea bro how to trick this O2 sensors? Let's say I'm using LT10s now, its still detecting fuel too rich rite? Because the stock ECU still there... If i not mistaken LT10s control injectors and ignition.
..thanx
