to retard/advance the cam timing... for either better acceleration or top speed...What is the reason of going for adj cam pulley?
u r riding waja single cam? or twin?Hai ZTH members.
What is the the best idling rpm after install adj cam pulley,now my car idling at 400 rpm and sound like motobot,very hard to drive along the traffic jem. Is there any pros and cons .TQVM.
yes... tune with dyno is better.... ideal setting differs from cars to cars as we all have different setup...some people did install the adj cam pulley but no effect in terms of performance. What is the ideal setting when install adj cam pulley?...perhaps tune it using Dyno is better?
do Dyno really see performance?yes... tune with dyno is better.... ideal setting differs from cars to cars as we all have different setup...
it should be installed hi cam condition...really depends on wht cams
adjusting pulley sometimes brings out magic
i saw a car jump from 320 to 360 , lol , ask kroolada :P
Bump: really depends on wht cams
adjusting the cam pulley does not set ur idle rpm...The adjustable cam pulley is common use with high-cam, in order to reset the correct idling.
for twincam yes... as u can set different cam timing for intake n exhaust.... for singlecam engines is different as both intake n exhaust cam timing must be set together...agreed,even stock cam with adj pully make wonder.
last time friend's 1.8 mivec dyno tune,if set correct can get a 5hp different.
5hp is consider a lot for a na application.
my owned L2s also with adj cam pulley and set different(retard/advance) feel different for the powerband at same rpm reached.
. So I was wondering whether anyone out here has the same desire, but just can't find one
