where is clanzkiller wshop?
A Z Auto & Modification @ A Z Motorsports
12, G FLOOR, JALAN 7/155,
BUKIT JALIL INTERGRATED BUSINESS PARK,
58200 KUALA LUMPUR.
58200 KUALA LUMPUR.
have to work, or else cant go for BOT hahaha
Already let my mech overhauling the engine, so i will call him to check it out for the TB and carbie. Hope can return to normal.
This coming fri should no problem since not working anymore back to full time student hehehe...
he is running carburetor... i think he confuse between throttle body and carburetor...very confusing, u got a TB & a carbie ? r u running fuel injection or carburator la bro
first of all your engine should be a EFI version.... then your air cond should be trigger by electronic also.... EFI car has got a electrinically controlled by pass valve to allow the engine to spool to higher RPM....
most of the time after year of usage.... the by pass valve is either spoilled or filled by dust or dirt.... maybe u try to take that by pass valve out and check if it is still working.... then use an air gun to clean up if the valve is working.... GOOD LUCK
Thank you..
But actually what type of car u talking about? cos it might be different?
... the service that they...
