- Joined
- Jul 5, 2006
- Messages
- 1,690
- Points
- 1,648
Just my 2 cents opinion...look at it u r 'downgrading' ur track car set up...there goes my banana,wastegate n turbine...now masuk stock manifold with evo 2 turbine...new intercooler...standard bov too...:P
Evo3 engine mods for track use..
1.Banana + 20G + w/gate - fine no need to change...but boost higher 1.5Bar..to boost higher u have ensure that AF ratio matched all the way and metal gasket 1.5mm nice...mayb need to upgrade injector at least 700cc + Fuel pump. if got budget go for steel braided hose for fuel line + aftermarket rail...put fuel surge tank + 2X bosch 044 pump better for 500hp...if low than 400hp no need...
2.Look into cooling system..upgrade oil cooler kit (the best use 2 of them) ...Aluminium rad..realiable one (upgrade fan if necc)...bigger intercooler...oil catch tank...
3.Brake system + Suspension set up..
4.Racing cam is an advantage if got budget...
Anyone have a good all-in-one centre to recommend?
