thanks for the reply... ;)Originally posted by FocalPoint@Jan 24 2005, 09:40
Hello! NiCkY7.
Generally, you start with low viscosity oils for new engines and progress to thicker oils as the engines age.In your case if you find that when using 20W50 there is little oil consumption, you may want to try out say a 15W. And if the oil level doesn't go down significantly, you may want to try a 10W.You will have to constantly monitor the dipstick level though.
Generally 0W30, 5W30 and 10W30 oils are energy conserving oils. You can read this on the circular API "doughnut " sticker at the back label for American oils. These oils have lesser loads and flow faster.
currently i using bardahl 20W50 mineral oil... and i thinking switch to bardahl semi-sync 10W40, cause i found that this model of semi-sync just around RM50... :D
so is it ok for me to straight using the 10W40 or i need to try 15W50 oil 1st?
thanks... ;)
i think some of the guys from jb in this forum will recognize this car (i should change color,plate,rim...
