TSD Boron Nitride Thermal Coating
stevenV6
Delevoped in the USA,TSD Boron Nitride Coating is a revolutionary coating that helps to improve heat exchange efficieny.Where TSD coating is applied,it will improve thermal management by reducing internal temp. by 10%-20% effectively.
It can be applied to virtually any surface/material that can benefit from better thermal management or surface protection.
Applying the TSD thermal coating effectively extracts heat from the heat source.The heat is quickly directed away and cooled by temp. differences.
In addition,the thermal coated surface forms a white graphite-like protection layer against oxidation.The increased surface area will effectively allow more air-surface contact for cooling.
The coating process does not require special equipment, dries quickly, can withstnd heat of up to 200 degrees celcius and easy to use.
Car components to apply:
-intercooler
-radiator
-AC condensor
-turbo kit
-engine
-brake caliper
-valve cover
-extractor
-intake manifold
-and many more......
TSD red (up to 200 celcius) : RM299 per bottle
TSD blue (up to 1500 celcius) : RM399 per bottle
Interested may contact:
STEVEN 016-3943182
its very long lasting on the surface......even u use a high pressure water spray on it also it wont fade....
UNLESS, u scratch it with a knife.........:biggrin:
bro, per bottle how many liter? the blue one can coat exhaust manifold?
1 bottle 200ml................
TSD red also can coat your exhaust manifold....only require 50ml to fully coat it...
BUT, if u wan better performance buy TSD blue....
cheers!
all pm replied............................
pm replied..............................
B.U.M.P
thx to lancer Gt for purchasing TSD.................
bump.........:smokin::smokin::smokin::smokin:
Bump: thx to lancer Gt for purchasing TSD.................
pls call for best price..............016-3943182
steven.....is it ok if i apply the TSD blue to the whole exhaust manifold. turbine. downpipe? would it be suffice for just one botttle?
definitely is ok........but u need 3 bottle to coat those components.....
but TSD blue now out of stocks...only left TSD red......
hv to wait for next shipping........
after use it , can tahan how long ? pm me best price to sarawak
u got PMed......................
Bump: all of the buyer will got the installation cd as well...............................
