Bro, I 've got no idea on CAMPRO engine. But to confirm it, U need to check on the Bore(diameter) and the Stroke of ur engine. Because those are the things that determine the fitting.. And most importantly, the method of holding the piston onto the conrod and the diameter of the piston rod. For example, Mitsu uses force fitting piston rod, toyota and nissan uses clips.
can. But u need to bore up the block to 81mm. Then U'll have 1.6 instead. Some ppl said max boring is 2mm in diameter... Not for this case... because the block configuration is exactly the same as 4G92. I have a friend already done it and turbo charged the engine.
Need some advise from u guys, i'm using gsr engine running with head mivec, using 1.5 cable gbox, already modified to gsr flywheel, clutch trinity 9'.
I feel dat the ratio is too short during...
Does anyone using this boost meter .. i just bought this boost meter from chopshop but seem cannot find any inlet to put vacum hoses into it .. does...
