4G91 Gang..
Bro... u should do a google search on gears. Firstly you gotta know how gears work in order to know what the numbers mean.
By gears i don't mean gearbox, i mean just simple gears. =p
You can get a good explainatino as well as animated guides at howstuffworks.com. Thats where I usually go to last time when I just started learning bout cars.
hey thx bro for ur info.. appreciate it:adore::adore::adore:
I tink i will take the 4g92/93 f5m222 vvkf gearbox , it from a 1.8 mitsubishi carb . From what car then i duno liao . So does any1 try this gearbox before ?
i already to try for this gb in my 4g91 but have a problem...pickup is shit. but top is ok lah... i just only 2 mnth bcoz minyak manyak sakit lah4g91 cant to suportlah... now, i use a mirage rs or mivec gearboc...its dificult to find bro becouse my gearbox its limited... i get in klang halfcut at rm1.6k... i forget about the code of gearbox, i thing is b00... jc7839... now, my 4g91 can beat the mivec becouse my pickup in gear 1, 2 n 3 can beat the mivec or vtec.try to find this gearbox n u can get a powerful to ur 4g91...
I got this gear box under rm 900 is the same as u say b00 jc 7839 , but is a pump type . iswara want convert pump very hard . can u check for me this gear box can change inside pin from pump type to cable type ?
YA , 4g92/93 pick up is abit slow , but top is ok .
Wat about this b00 jc 7839 ? pick up is good , but wat about top speed ? Can tell abit ? urgent .
If I change the pump pin to cable pin type , will the performence drop ? Cost alot ??
if not my mistake, boopat is vr4 kod for gb galant vr4 uk spec n boobol is 1.6 rs, i not sure from mivec or 4g61 rs but is specipic rs to mirage... you car can easy to pickup n easy to become a top.. my car is standard but can easy to reach 200km... i thng better u use to cluth pum to get a good respon to ur 4g91....
My firewall duno can mod or not , there is no plc to mod . already got the double layer brake pump there , so i m asking can this gearbox change to cable type, will it effect the performence .
i'm not sure about this becoz cluth pump more easy campare cluth cable... but if u use this gb, better u use cluth pump.. and 1 more, bdk2 saga like this gearbox to 'kahwinkan' dgn engine.
pickup is superdamn nice n more power... ..
hi greeting to all sifu 4g91 gang,
Need some advice,i use 4g91 engine with 4g93 wiring and computer box.i have air cond problem,need to use aircond valve(FICD) otherwise my engine jerking,Did anyone experience same problem like me?Thanks in advance for all your comments.
just combet to 4g91 last 2 month .. total spending 5.5 k complete..
:biggrin: very good the fuel comsupmtion
yeah man, so many new members~ Welcum welcum...
Btw, clutch pump or clutch cable... is like power steering and no powersteering. The clutch pump is there to take off some load on your leg muscles! LoL... in other words, the clutch will be easier to tekan la. =p
Low cc cars, or less powerful cars do not require to have heavy force on the clutch diaphram (spring). So those usually they use clutch cable to save cost, coz' not required. More powerful cars require heavier spring, therefore they opt for clutch pump setup to take some load off the heavy spring.
IF you're planning to drive the 4G91 with stock clutch, then by all means get the cable. IF you're planning to put in racing clutch, then its better you convert to clutch pump. The racing's diaphram has quite a stiff springrate, so there's a lot tension in the clutch cable. You don't want to drive halfway then it putus man... =p Or worse, damage your firewall... as the tension is high, and then u press letgo press letgo press letgo the clutch, the clutch cable is like slowly 'sawing' through your firewall.
hi,anybody now if our wira can use the Front Lower ARM EVO3???but the EVO 3 don't have the place to connect to the antirollbar....so how???because last time i use the Rear lower Arm set EVO3 into my wira r quite cun,so plan to change the front(ori one also got problem already) but find this problem...pls help...:banghead:
hi,anybody know if our wira can use the Front Lower ARM EVO3???but the EVO 3 don't have the place to connect to the antirollbar....so how???because last time i use the Rear lower Arm set EVO3 into my wira r quite cun,so plan to change the front(ori one also got problem already) but find this problem...pls help...:banghead:
evo3 front lower arm can b used on wira.....
just ask ur mech to weld a bracket to fix the ARB.....
