camshaft more overlap more power,lift hi to open valve more take air and fuel
Hi, what i understand is if the duration is high,say 272 above is good for higher rpm or top speed not for pickup right?
long or short duration cams lor
oso got retarded cams, advance cams
even got "low" or "shortie" cams
all sort of cute names to make it interesting to potential buyers lor
That's y i tot hi cams will exert more force to your valve.. cause the profile is more sudden.. sharper peak and the curvature more curved.. if you get wat i mean..
272 will be reasonable for street use while giving u reasonable driveability....What degree will give most good pickup increase?
yeap.... high valve lift allows more air/fuel to enter... longer durations allows air/fuel to be delivered at a longer duration...camshaft more overlap more power,lift hi to open valve more take air and fuel
http://s.lowyat.net/style_emoticons/default/laugh.gif http://s.lowyat.net/style_emoticons/default/laugh.gif
thats why u need stiffer valve spring...
Where can i get this stiffer spring ar?:hmmmm:
depends on ur gear ratio (how big ur final drive is) and ur launching rpm (depends on traction - tyres).Hi, what i understand is if the duration is high,say 272 above is good for higher rpm or top speed not for pickup right?
woooo, u must go to uni and ask what kind of degree course they offer lor
u wan bachelor in wat ?
or u wan doctorate ?
hehehee, kidding, i siao siao today :stupid:
viswork??...Hehe..degree in doctor ayam...my hand are itchy to get this hi cam for my car.Can anybody suggest a good workshop in JB to tune it.:hmmmm:
wat's the stock duration for exhaust and intake angle? anyone noes? for wira se i mean..
For SOHC 4G13~15 engines, wat we use to do was grind the heel of the lobe by a couple of mm and then compensate it from the rocker. We get slightly more valve overlap and thus, a DIY-ed "hi-cam" Abit more OMMMMPPPHHH!!!
i've heard of mechanics grinding a few mm off place where the rocker arm shaft sits... this lowers the rocker arm and hence allowing higher lift on standard cams....
Yes, it works just as well. either grinding the, as you say it, "rocker arm shaft sits" or grinding the cam's lobe heel, will result in higher lift & more overlap and you have your DIY-ed "hi-cam"
When the cam lobe heel is grounded off, there will be a larger clerance between the heel and rocker arm.
Using a feeler blade, you need to close down this clerance as you would do when you adjust the rockers arm screw to get rid of the irritating the infamous "tappet noise" problem of 4G15/13
Yes, slight longer valve open duration and higher lift. if not mistakne, we grounded 2mm off the cam lobe's heel.
wah.. pakai grind grind oni ah.. dangerous leh.. all diy king here..
The lack of handling and grip is there when taking corners...
