EF2 swap big V
mdsb3
hello fren..ef2 swap big v from eg6:
1.any modification on engine mounting?
2.can use wiring obd0?
3.can use eg6 dashboard?
4.any mod for driveshaft?
TQ
1. gearbox mounting, yes. a bit. but not that obvious
2. if u have d complete wiring from the EG6, use it.
3. please. do not do this. it will NOT look good at ALL.
4. EF9 SiR driveshaft can be used for this mod
also, do not forget to upgrade your fuel tank + fuel pump to vtec model (CRX EF8 or EF9). i dont think u can fit EG6 fuel tank on the EF2.
if u need eg6 complete engine, call me.
b16a manual
-dashboard
-complete wiring
-ecu
-g/box
0122479536
thx
2. can use dashbord ef wiring + engine eg6?
3. can use crx del sol dashbord?
4. ef9 driveshaft pnp?
how about with b18c gsr? any major mounting modification?
Mr. Lightningfields
have u seen ppl put gsr dashboard into EF? any comment?
mdsb3,
1. no problem
2. can. but again it wouldnt look THAT nice tho.
3. ?
budin99,
b18c GSR or Type-R also can be plonked in EF. as far as i know the only mounting needs to be modified is the gearbox mounting as EG,EK,DC is different than EF. the rest shouldnt be a problem.
as for the dashboard, have a look at this CRX with DC2 dashboard. personally, i think it is just OKAY as i prefer a car to retain its originality. if youre willing to spend your money and time doing this conversion, why not. i can say that there will be a whole lotta cutting, grinding etc to imperfect the fitting of d dashboard..andddddddd bear in mind you need to cut the door panel/custom made to fit it with the dashboard, which is the last thing on earth i wanna do to my car ha ha.
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg0MDM2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MjQ2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MjU2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MjY2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2Mjc2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2Mjk2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MzE2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MzI2czQxM2RmZDMxeTU0MQ%3D%3D
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNjg2MzQ2czQxM2RmZDMxeTU0MQ%3D%3D
