Carburetor Section
How to know whether the fuel too much or the air too much?
too much air... lean mixture... engine vibrates at idle... rpm drops significantly and unstable idling...
too much fuel... rich mixture... engine idle smoothly but yet can feel abit rough compare to stoich... overly rich mxture can see black smoke coming out from exhaust...
hye... Im a newbie here.. Im using proton iswara aeroback 2003 special edition.. I want to know how to increase the speed of my car n which mechanic/workshop can do the tuning for my carb ?
Ooo.. you found the right thread. A lot sifus(theo,sky,fred..etc) here can teach how to make carb engine goes faster. They really a good "poisoner". Haha.
*bump bump for this thread*
iswara put in mivec, ur mounting need to change...and surely u cant get approval fm jpj unless bribe (3k above), engine 6k above (halfcut, if u can find one), workmanship (1k above), other replacement parts, timing belt, oil, oil seal, valve seal etc etc (bout 1k)... u campur everything together will goes to around 12k...we dont call himsifoo walker for nothing.
ooppss.... i guess 12k not enough lah... previously a friend of mine transplant GSR inside his wira... plug n play also cost him about rm12 for everything...
mivec halfcut cost about the same as GSR... bribe jpj 100% gonna need more... so total up will be about 15k lah.... kekekekekeke....
unless if u got lubang... try get rojak parts around... (mayb ur mechanic got lubang)... 4g92p block, rojak mivec head, rojak some other wiring, bla bla bla... jpj, dun give a fcuk lah... keep ur car in stock standard look.... prolly will cost about 7k-8k... and thats if u dare lah... :P
Abang sky.. pls dun teach other people to simply sumbat things ya.. :P.. we oways follow undang..undang wan.. no play..play..:D
