Doubt about gearbox for blacktop ae111
chorgiap
Sifu, I'm using toyota seg ae111 converted to Blacktop with 5speed manual without LSD. My gearbox gone last week, went foreman thr replaced with another one. The foreman told me it is BT's original 5speed without LSD gearbox but what i felt is got different in gear ratio compared to the old one. How to test whether it is original BT's gearbox??? Before this 120km/hr at 5th gear = 3800rpm.. now 120km/hr at 5th gear = 3500rpm. I doubt he putting silvertop's gearbox.... any different between this two??? Or can it be ECU problem
Anyone using blacktop can tell me? Thanks :adore:
now gb u used could be from svt engine.. which called c52 gb...
Black top or end batch of SVT gb called c56 gb which has close ratio...
as u said... 3800rpm at 120km/h =bt gb cus i was using it.. almost same reading
fren using c52 gb .. slightly lower... hahha
err..
c56 and c52 using the same ratio on the 5th gear.
based on calc, using 195/55 series tyre, on 3800 rpm speed should be 117km/h. so confirm your old gb are 20v's
method of testing : you cruising at 5th gear, slowly climbing to 3800 rpm. and take your speed reading
possibilities: both gb have different Final Drive or different gearing
if using gearing from 4efte, at 3500 rpm, ur speed should be 125.3km/h
and your gearbox 'gone'? hard to engage? housing broken? what happened?
and lastly, happy researching!!!!
err..
I'm using 195/55/15 tyres. cruising at 120km/hr rpm = 3500 for dis gb. D old gb 120km/hr....
err..
oh ya, housing broken and 3rd gear can hear a crrrekkk sound when engage..
the old bt gb housing crack ande 3rd gear produce crrrrekkk sound when engaged.
I found another gb :5speed with LSD. Shall i put it on my bt? or 5speed w/o LSD better??? need opinions lah.. Thanks
The LSD and Non LSD driving mood abit different.... With the LSD Gb need to used to it coz different control oledi.... specially when U turn and cornering....
with the same speed and same gear , you are getting lower rpm should be ok mah...better FC...Last time your rpm is 3800, now its 3500,consider good mah....
fc better but pick up speed slower:biggrin:
thats sumthing u have to consider for better FC though....hehehe:D
go ask ur mech wat on earth he can change wrong for u ...or he tertukar wit others.......
Hi, can I know if the gearbox for blacktop AE111 LSD has 1 way, 1.5way or 2 way?
Ya loh, pick up significantly slower then my previous gb lah. Since i'm so "lucky" to hv chance to try both C52 and C56, wud lk to share my opinion hr. Ofcoz c52 top speed better but d pick up much mr slower, u hv 2 tekan kuat2 and then waiting the rpm 2 come up slowly and each time when u shift gear the rpm drops mr then c56, nt lk c56 closed ratio...wao... and abt fc, actually nt much different between them, may be in highway d c52 better bt if it is combination both city n rural, u tend 2 tekan mr to get mr pick up as in c56.. so for me i prefer c56 lah. all dis based on my feeling la since i never test with any scientific equipment... correct me if wrong.
