SIFU NEED help on Blue Smoke
Jack_Hon
HI,
I'm having a problem is, Alot blue smoke inside the engine, and so smelly around engine, smelly like engine oil plus patrol,........BUt ho......My engine still power....exhaust no colour smoke also.....one kick start engine then run......all look normal...........Help here.....
ENgine oil : Extreme power UP....10w50....semi sythe
Engine specification : Na engine bolt on turbo
FUel : Patrol unleaded super
Compression ratio 8 : 1
I have added oil catch tank.....: from Engine valve cover to tank then to land..
no suck valve cover smoke back to intake manifold...
engine oil smely patrol, it's piston ring Kong edi ?.....piston ring kong car also power, no boost also power........pity la ! help
have u check for leak?can hardly understand bro.:)
Leak how to check, all the place surround engine i checked.....except.inside engine hhahaha.............
compression tester.....no the tester how check........if compression ring worn not need use tester also know......my blue smoke inside the engine is so sosos slow move, now like blow by can see the smoke move.........So pity le..help
can use vacuum gauge and estimate the cause ar??... coz i jz noticed my exhaust also emitting a little blue smoke....
check every inch of your turbo manifold, every gasket area, turbine, downpipe.
I've seen a turbo car with smoke coming out of the rocker cover breather hose..
very very bad condition.
ALL checked........
