Basic setup ICE for beginner
inside0ut
hi guys..
wat the best setup (ICE) for newbie & tight budget like me?
recently i change my oem HU to dvd one..(but no monitor yet)..so wut shud i do next?get speaker?amp?or monitor?plz advice..
regards,
mie!
yeah lor... wats ur budget... have to state nicely... otherwise u might get heart attack if u ask tohsan kor to rekomen :P
err..my tight tight budget is max 1k only...thats for now..mayb later slowly upgrade to better one la...thanks bro tohsan & bafukie for ur attention!
just get the monitor la since u oledi got the dvd player, sound can still use OEM speakers. obviously youre into AV instead of SQ...
tohsan kor...ur signature enough to tell whether u r a high/mid/low end ICE user ... hahahahahaha
decide between the 2 which one you need.
Sound or visual?
Sound - get an amp and comp set. (get 2nd hand for both items, probably can sound good enough)
Visual - get a monitor. (if you go for cheap ones, probably got some money to spare for comp set)
thanks for ur respond zenn, cacin, tohsan & bafukie.
im more into audio actually.mayb monitor can add in later rite?
so,within +/- 1k budget, what the best setup i can get?which brand is ok within that range of budget?really need sum advised here...thanks guys!
haha....u go market place...howiechoo selling 2 channel amp and matria comp set...juz RM199....and buy a eclipse c1000 player from him too...juz RM3xx also....
Bro Zenn has a DLS B6 comp set for sale at RM500. Look around this forums or other ICE forums to find cheap 2nd hand good amps and/or components.:biggrin:
try perfect-carpenter's thread in this forum. he got 3 amps for sale.
thanks cchcchcch & cacin!
the hunting begins! :P
will update with u guys if i found one...
anyone know about PLYE amp?izzit trusted low cost amp or so-so?any comment?thanks!
SPEC:
PYLE AUDIO PE-354 75W RMS x 4 Channel Mofset Amplifier
Model: PE-354
75W RMS x 4 Channel Amplifier @ 4 Ohm
Full MOSFET Power supply
2 ohm stable stereo
Variable Low Pass : 50Hz-500Hz
High Pass : 50Hz-500Hz
Frequency Respone : 10Hz to 30KHz +/-3dB
S/N Ratio : 98dB
T.H.D:> 0.02%
Full Selectable Crossover : High/Flat/Low
Tri-Gauge Protection Circuit
4 Gauge Power/Ground Connections
Thermal Overload Protection
Chrome plated RCA Connectors and Screw Terminals
Made In Taiwan
SPEC:
Model: PE-354
2 ohm stable stereo
S/N Ratio : 98dB
T.H.D:> 0.02%
Made In Taiwan
How much were you offered for this amp?
old school pyle amps = american cap ayam
current pyle amps = china cap ayam, hehe...
