YEAH. 4G93P. IT WILL GO FASTER AND FASTER WHEN YOU FULL PEDAL UNTIL THE ENGINE IS BLOW. JUST MODIFIED YOUR INTAKE AND EXHAUST SYSTEM THE RIGHT WAY AND USE THE ORIGINAL 1.8 GEARBOX. BELIEVE ME. HAA HAA HAA...
ENGINE CAN BLOW BUT DON`T MAKE IT BLOW LAH. BUT WHEN YOU REACH YOUR TOP SPEED TARGET START SLOWING DOWN LAH BRO. DON`T ACCELERATE ANYMORE. I PUN TAKUT WOO LAJU-LAJU. VERY DANGEROUS MAN...
bro jacksonlow....
he said he's using 4g93p....P is the engine used in proton...
like the wira 1.8 dohc 4g93p.....
if mistu japan would only be 4g93 w/o P...
This is mine. Actually reach 180 already when sudenly a C22 cut onto the fast lane and i lift of the pedal so didn't manage to get the 180km/h shot..Aii...Oh its a Nissan Frontier by the way...
HYE BRO. MAYBE YOU THINK DAT I`M A LIAR. OK. I TELL YOU THE INFORMATION THAT YOU MIGHT NOT KNOW.
THE PICTURE IS NOT FROM MY CAR( COZ I DON`T HAVE ENOUGH GUTS TO DO DAT). IT FROM MY FRIEND CAR. HE`S USING PROTON SATRIA CONVERT TO PROTON 1.8 ENGINE.
HERE IS THE LIST THAT I KNOW ABOUT HIS CAR MODIFICATION.
1.8 PROTON ENGINE(4G93P)
-APEX`I OPEN POD FILTER
-LARGE DIAMETER THROTTLE BODY
-AFTERMARKET FUEL RAIL
-GSR TURBO INJECTOR (390CC)
-MIVEC HIGH COMPRESSION PISTONS.
-METAL GASKET
-282 HIGH CAMS
-ADJUSTABLE CAM PULLEY
-AFTERMARKET VALVE SPRING
-FULL BALANCING ENGINE
-IRIDIUM SPARK PLUG
-MODIFIED ECU
-4-1 TUNED LENGHT EXTRATOR
-2.2 STRAIGHT PIPING WITH HKS HYPER MUFFLER
-LIGHTWEIGHT RIM WITH SEMI SLICK TYRES
-REMOVE REAR SEAT AND SPARE TYRES
THAT`S IS ALL THAT I KNOW. I NEVER SEE HIM ALMOST 5 MONTH COZ HE MOVE TO KL. OK. I HOPE THIS STATEMENT CAN MAKE U GUYS UNDERSTAND AND WON`T THINK THAT I`M A LIAR. THE PICTURE IS CUT FROM THE VIDEO AND HE SENT TO ME THE PICTURE. I TRY TO REACH HIM AND ASK HIM THE VIDEO SO THAT I CAN SHARE WITH YOU GUYS LATER.
OK. THANK YOU...
Falken new FK510, which is said to replace the older FK453. Wonder when will this tyre arrive at our shores and how it fares with other new tyres being introduced...
to guys who has wastegate install in their cars . wat will happen if the vacuum hose to the wastegate is popped out , meaning leak or come out ? will ur boost gauge still be able to read the boost ? coz i was...
Hi Guys i have a few injectors here ,side feed..from what i was told it's for silvia sr20det...but i'm not to sure .,one of number read 06806624 and the other is A46-00...also it has a black dot on the injector
